FS Freeway Flyer, Replica Fuchs and Floor Pan
RAW069 - September 18th, 2016 at 08:07 PM
Recently rebuilt swing axle trans, built up as high performance with following specs:
Freeway flyer with 3.88 r&p
Super diff with 4 spiders
HD shift forks
Welded 3&4th gears
1st 3.8
2nd 2.06
3rd 1.32
4th 0.89
Comes with long axles and tubes
Car has been sitting around for a couple of years and is now completely stripped and changed to IRS hence change of gearbox needed.
It was only occasionally used and never abused.
Pics are on gumtree, as I can't workout pics here, or I can send pics
Located in Adelaide
$2000
RAW069 - September 18th, 2016 at 08:12 PM
Perfect condition, no gutter rash etc
15 x 5.5's
5x130 Porsche stud pattern
Pirelli Cinturato P1 tyres, 185 65's front and 205 60's rear, with barely any wear
Chucking in rear beetle drums (later swing axle) that are drilled to 5x130. Your fronts will need drilling to 5x130 which any decent machine shop can do for little $$
$1300
Message for pics or see on gumtree
Located in Adelaide
RAW069 - September 18th, 2016 at 08:13 PM
69 Floor Pan
Rust in front left floor as well as frame head
Otherwise ok, suit restoration or parts
$200
Adelaide
RAW069 - September 25th, 2016 at 06:47 PM
Bump
