a few Subaru goodies
1303Steve - March 1st, 2017 at 12:49 PM
Steve Carter, Lugarno NSW 0490 020 338, don't text
can post at buyer expense
Autronic SM4 ECU to suit Subaru 01 - 05, comes with air intake temp sensor and fly lead $1500 ono
Subaru specific GTX3076 rear housing $350
I bought a GTX 3076 from TUSpeed in Melbourne with this .82 housing, I've gone V band with an external gate so I don't need this rear housing any more. It's been ceramic coated black and comes with both a stock wastegate controller or a Turbosmart one with 18 psi springs
Subaru 3 inch MSR dump pipe $150
3 inch stainless dump to suit a VW engine swap made by MSR a renowned Subaru tuner on the Central Coast. $150 ono Has been ceramic coated black and has a O2 sensor bung fitted. As can be seen in the 2nd photo the dump goes between the a arm and the torsion tube, my motor was moved 100 mm forward so a bit of modification maybe needed, most conversion have the motor moved 50 mm forward
1303Steve - March 1st, 2017 at 12:50 PM
another photo of dump
