Recently removed of a daily driven 1966 Split bus.
SOLD: Front axle drum to drum. Recently replaced brake shoes, wheel cylinders, and centre pin.
SOLD: Rear axle drum to drum. Gearbox code H9008300. Runs well. As usual, the 3rd-2nd syncro is worn. Recently replaced brake shoes, wheel cylinders.
No starter motor. Has beetle nose cone.
SOLD (pair): Split bus spring plates
SOLD: 5 x 205 wide 5 bus rims with 205/75R14. Good tread on 4, will clean up nicely. Hub cap clips in place. Spare is worn on one side (bottom wheel
in photo). Prefer to sell as a set.
SOLD: 3 x hub caps to fit wide 5
Ghia parts also for sale from the stockpile:
SOLD: Original steering wheel from a 1963 Karmann Ghia.
SOLD: Swing axle gearbox and starter from the same '63 Ghia. Condition unknown. Needs a good clean.
Pickup from Baulkham Hills, NSW. Shipping can be arranged for all items at buyer's expense.
PM for details.
