6v Engine wanted
grazza7755 - November 20th, 2017 at 07:31 AM
I'm after a 25 or 36hp engine, rebuildable in any condition or rebuilt in good to perfect condition.
It's for a 1955 Single cab.
All possibilities considered.
Graham
0408 297 030
grumble - November 20th, 2017 at 06:08 PM
Grazza, I have a couple of engines in Taree neither are goers, one is fairly complete but missing the fuel pump I bcan send a few pics of this one to your email if you are interested. The other not complete but is under cover and will take a bit to get to but it can be done if you are interested.
grazza7755 - November 20th, 2017 at 06:43 PM
Could be a possibility.
Are engine numbers available, just to check years?
grumble - November 20th, 2017 at 07:14 PM
The accessible one is 27324272, I think the other one is earlier
grazza7755 - November 21st, 2017 at 06:05 AM
Thank you, I'm am hoping fpr a 1- number so will keep in touch if needed.
mossman - November 21st, 2017 at 06:50 AM
Hi Graham,
you could try this guy in Brisbane.
https://www.gumtree.com.au/s-ad/kangaroo-point/auto-body-parts/vw-engine-beet...
grazza7755 - November 21st, 2017 at 07:15 AM
Thanks for the tip however that is a 40hp engine.
You can see that the generator stand bolts on to the case where as the 25 and 36hps are one piece.
vw54 - November 22nd, 2017 at 12:46 PM
Graham
I have 3 36hp blocks 2 x 2mill and 1 x 3mill numbers
unfortunately no good for your 55
db
