WTB Industrial Engine air cleaner - Got one
Pattison - April 4th, 2018 at 07:25 PM
Hello vdubbers
I'm after an air cleaner for a 1600 single port industrial Engine.
Engine runs a Compair compressor. Also after a user manual for the unit.
Thanks in advance.
Rel
0408608901
mackaymanx - April 4th, 2018 at 07:48 PM
Manual
https://forums.aussieveedubbers.com/viewtopic.php?tid=112735&page=1
Pattison - April 5th, 2018 at 06:14 PM
Hey Brent
Thanks very much for the link to the manual. This manual will help as the model it covers is similar to mine.
I was hoping to get a manual to the exact same model. I have included some more photos to help narrow it down.
I did some testing on the weekend and it builds pressure and then shuts down and just chugs over until more air is required then it revs up again and starts pumping again.
if you don't start using more air and it is left chugging then the engine shut off completely. I would of thought that it would just continue to chug away. The main problem with this happening is all the air needs to be released before it can be restarted.
must say it remarkable how much air it pumps.
mackaymanx - April 6th, 2018 at 12:38 PM
Should idle at 1500 rpm for a compressor.
bushed - April 7th, 2018 at 09:04 AM
nice but pleeeese remove the fuel tin NOW....safety!
