WTB Empi Porsche / Chev pattern rear disc rotor
Same as theses ones
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D6745
Rel
Not interested in Sherman?
http://www.volksconversions.com.au/brakes.html
I would be staying away from anything Empi - especially if you want it engineered
I installed the Empi kit years ago and found the calipers too small as I have 10 inch rims on the rear so I upgraded the calipers to Subaru and they
work great.
Now I'm looking to swap to Porsche rims so I just need to swap rotors.
Hoping someone may have a set of rotors.
Hi Pattison,
I have all of these in stock, http://rodpenroseracing.com.au/7-discsrotors-hubs
Rod.
thanks Rod
Do Empi and AC use the same rotor? The link shows front rotors. Do you have rears?
