WTB: 32 34 PDSIT right side
hpnotch - August 8th, 2023 at 11:10 AM
Hello everyone
Chasing a 32-34 PDSIT (right side) carby bowl with good thread to snug down the idle cut-off solenoid (unlike mine which is stripped). Preferably just the bowl if you've got a spare or otherwise the complete carby - ideal if I could pick up from someone located in South East QLD but willing to pay for freight if you're willing to ship.
Cheers.
grumble - August 9th, 2023 at 08:33 PM
If you can't find one closer to home I should have either a complete carb or a centre section in Taree.
hpnotch - August 10th, 2023 at 08:03 AM
Thanks Grumble
I've sent a PM -not sure if it has gone through (no record in my outbox) -so I'll try again. Apologies if you get multiple messages!
grumble - August 10th, 2023 at 04:32 PM
No worries I got the message and have answered.
mackaymanx - August 10th, 2023 at 05:44 PM
I had the same problem with my type 3 carbs, I used this section from a set of bay windows carbs, I changed over the jets and fittings. It worked but there were some temperature bulbs on the float bowls that were different.
If I remember it was only this section that was compatible with mods.
Andy - August 10th, 2023 at 09:07 PM
Was the throat size different in the Bay window carbs?
