Hello,
Genuine Weber 44 IDF carburettors: $1250.00
Made in Spain.
Purchased from CSP Germany (air cooled VW hot rod shop).
Distributed by Redline.
The carbs are USED - like NEW.
Purchased the carbs for my VW Beetle.
44 IDF Webers were too big for my application.
The carbs have ZERO mileage and LESS than 20 minutes of running time.
44 IDF Weber specs - as equipped from CSP:
- Venturi; 36 mm
- Main nozzle: 135
- Air correction nozzle: 175
- Mixing tube: F11
- Idling nozzle: 50
The Webers come with 4 velocity stacks - two stacks per carburettor & 2 air filters.
NOT INCLUDED - intake manifolds, carb linkage, hose, hose clamps.
Pictures are available on EBAY.
Will load picture on aussieveedubbers, shortly.
Thanks,
Zayus
