I am after a pair of spacers about 10 -12mm for a wide 5 wheel, these go between the rim and the drum.
Dave
[Edited on 25-9-2004 by 57kombi]
get some alloy rod 2inch diameter and cut them or machine on a lathe.
I use these on my smoothie rear wheels to get the wheel to fill the guard as such.
You will probally need to use wheel studs and nuts when using the spacers
Thanks Dave.
I might give that a go
Dave
I have adapte plates ($400)
four 16x7 porsche tell dials ($600)
115x7 porsche cookie cutters ($130 each)
PH 0439725589
Bribie Island
[Edited on 15-12-2004 by Hamish]
man go to repco or peps or any auto acc mob and get a set $15.00 should do it i have a set of 4 should be what you need 2x10 and 2x 12 but truely get a set of new ones they are mulit fit
dave u lazy, just make em! supacheap and repco ones arn't wide enough for the 5 by 205 bolt pattern. or get some 5x205 to 4stud bug adaptors and drill the threads out as these are 10mm thick.
draw what u want and i will make them 4 u and ship
rob
