Am willing to split the 40mm venturis out of the carbs and sell the 44's with the origional 36mm venturi's.
The 40's suit engines that have had very decent porting jobs to the heads.
Persons Name –James C
Phone number –0418312852
Suburb / Post Code – Mount Dandenong 3767
Item Description - Pair 44 IDF Weber carbies for sale
Condition – excellent
Item Cost - $80 for 40mm venturis from Air cooled.net
- $770 for Webbers with linkage and accessories as below.
Webers are approx 2 years old with approx 20hours usage.
They have been jetted for my 2275. Would idle at 500rpm and rev to over 7500rpm.
Carbs come with:
Weber Carburetor Sync tool.
Standard 36mm venturai's
Stainless steel velocity stacks
Scat Hex linkage kit.
K&N airfilters.
Note: I am keeping the manifolds. (They are for superflow heads.)
I am selling as I am moving to a Holley single carb with a hair dryer.
[Edited on 12-10-2004 by vwfastback]
[Edited on 28-10-2004 by vwfastback]
WalterMitty,
You have U2U.
James C.
Note: Carbs are still available.
Bump
Rosebud,
Manifolds are approx $100 I believe. You can look for second hand ones, or mose VW shops can supply.
Depends on what you want to put them on to.
Cheers,
James C.
