1965 (I think) Floorpan.
Good pan halves... only light surface rust - comes off with wire brush.
Rear spring plates.
No beam - framehead for K&L.
Tunnel has been cut by some lazy sod to fix clutch. easy to weld shut.
Handbrake.
Pedal cluster.
FREE FREE FREE FREE FREE FREE FREE FREE FREE FREE
Come and take it away this week or it gets cut up and tossed. Moving and it can't come with me.
Matt
0417 409 023
9608 9129
Hinchinbrook 2168
Close up of the cuts
hey matt its hard to give things away on the forum i think people would rather pay for things , i have tried to give things away a few times . i also will be throwing my parts out probably get in trouble for it to
Then they can have the pan halves for $5 and I'll throw in the backbone and the rest of the chassis
bump
I'd hate to see this cut up and thrown out.
I'll gladly take this off your hands.
Sounds like a safer bet than the bottom of my '62. It's always an adventure when you finally take the body off.
If you can get it before Sunday it's yours...
I'll call you - I should be able to get it on Friday arvo or Sat at the latest.
You can call me on 0421 285 423 if you need to.
Thanks,
Tim.
