I am looking for a supplier of a lowering kit for a 66 Beetle from the USs. The unit I am looking for does not require the beam to be cut through and
the adjuster welded in the beam, more the adjuster has teeth that weld onto the beam and allow adjustment that way.
Can anyone help me put a name to these devices and provide me with a US supplier?
Please send me a U2U with info.
they're called avis adjusters
Gene berg
there available here in sydney
They are stub axels which are in a 2.5" higer position therefore lowering your car. More importantly your suspensions stays std.
Is your front end link pin or ball joint? these are for a linkpin and Disk brake conversion.
$500
Ph 0439725589
[Edited on 9-12-2004 by Hamish]
