For Sale MSD Multiple Spark Discharge 6AL *SOLD*
1303 - December 19th, 2004 at 08:56 PM
For Sale MSD 6AL Multiple Spark Discharge Ignition.
Comes with wiring harness/diagram ,Plug in Rev Limiting modules 3000,6000,7000 and 8000 rpm. The unit is under 12 months old and is in perfect condition with not a mark on it. Check the link for the run down.
I paid $485 for it
http://www.msdignition.com/ignition_6.htm
Sell for $380
Paul
Erina
0410 309 979
[Edited on 19-12-2004 by 1303]
[Edited on 4-1-2005 by 1303]
1303 - January 2nd, 2005 at 09:04 PM
Bump
Dannyboy - January 2nd, 2005 at 09:50 PM
What would the ideal ignition be to go with that?
Cheers Dan;)
1303 - January 3rd, 2005 at 07:38 PM
Anything really, as the ignition only switches the MSD. I did run Pertronix with this System but points can be used. If you use points there will be minimal wear on the contacts due to less arking because there is only switching current through the points instead of the normal load of switching the actual coil.
You will still need to set the points periodically as the rubbing block will wear as per the standard set up.
The good thing about the MSD is it sparks for a full 20 degrees crank rotation under 3000rpm which helps burn all the fuel .... thats when good things happen.
