FS BNE: Swing Axle Parts
bugmeister - September 30th, 2005 at 11:21 PM
Hi,
Following my recent conversion to IRS, I have the following bits for sale.
***SOLD*** 1. Camber Compensator. Not sure of brand but has urethane centre pivot, urethane outer "fingers" and a zinc plated bracket. The actual torsion beam (for lack of a better word) is plastic coated, but it has flaked off in area. Otherwise is is good condition. Made a night and day difference when i fitted it. $50.
***SOLD*** 2. 1300 Swing Axle Box. Complete with torsion bars, spring plates, and complete drum to drum. Was working perfectly (no noise) in my car prior to the switch. Has recently replaced Brazilian shocks, 1 recently replaced wheel cylinder, ditto for 1 drum, boots and the shoes. $80.
3. 1300 Swing Axle Box. No axle tubes. $50. ***2/10/05: Now with axles and tubes. ***
4. 1300 Swing Axle Box. For parts, jumps out of 4th. $30.
Also have 1 spare drum and axle. And complete 4 stud rear drum assembly (drum, backing plates, cylinders, shoes etc.) in GC...simply switch on if your's needs overhauling.
Located in Brisbane. 0413 018 657.
Peter
[ Edited on 2-10-2005 by bugmeister ]
Anthiron - September 30th, 2005 at 11:26 PM
is the 1300 box drum to drum wide 5?
bugmeister - September 30th, 2005 at 11:39 PM
Surely is.
