ok peoples ive just got this little beauty back off another car. i have one twin barrel progressive carb, manifold and air-cleaner that has just come
off a 1600tp bug and was running well. the only reason im selling it is cause im going back to my 2L t4 motor shortly and i could do with the money
for the resto of chaos. the carb is a twin barrel progressive off a lada niva, its exactly the same as the webber but doesnt have the trademark on it,
it is a vacuum secondary version which has the adjustment jets at the front of the carby as you look at it in the engine bay. i also have the webber
that i got with the manifold but it was a pain in the arse as the adjustment is against the fan housing and it was a mechanical secondary. i will sell
this with the manifold if you want it instead of the the one im offering. bear in mind that the one im selling ran better than the actual webber i had
on there and i ran this for about 2 years before i had an engine failure not related to the carby
any way i want $350 for the lot as i know that the carby sells new for $300-400 and this is a complete set up ready to bolt on to a T1 motor.
you can contact me ether on here by u2u or on my mobile 0409550588 after work hours as i wont be able to answer it during the day due to courses.
also if you ring please give me your user name and real name as it can be confusing. cause i answer to barls at work as well but my real name is dion
bump come on someone must want one of these
nobody wants one of these, i dont get this a couple of months ago people were climbing over each other to get one but now nothing. so bump
ok looks like ill keep it till some one wants one ago
still no one
patence grasshopper
bump and heres a pic
