prefer in sydney area must be in good working order
darren
penrith 0425 269 516
not in sydney..am in perth..but have a red L bug box....sourced it through neil(seagull) and havent put it in car yet so he should know the condition
of it....was told it was in great running order.
Anthony
[ Edited on 13-2-2006 by 71superbug ]
might try alittle more local at this stage but if i get desperate what would the cost be to get it to sydney
darren
100kg set me back close to $400.
g-box ain't that heavy tho
Good to see you taking the plunge with the irs. Just make sure it isn't lower than mine.
Nik
will fit the front end aswell , just trying to decide on the best way ,keep link pin or machine up some ball joint arms and use the discs on the 68 front end in the bus allready??????? delemas delemas
can you open up the bushes in the beam to take the BJ arms?
gearbox can be lifted by one person without too much hassle..will weigh it up and ask them anyway...always good to know.
will post tomorrow how much it would cost to send.
Anthony
I have a box up here in qld that could freght.
Brendon
Speaking of Lbug 'boxes
Neone got an 3.88 Lbug diff/pinion laying around?
I need one for a future project
L8tr
E
gearbox weight 41kg.
Go for type 3 they are a bit stronger.
Fred
HAY NIK , IS THE PMG AS LOW AS MY 58 !!!!!
Pardon my ignorance, but what makes a type 3 gearbox a bit stronger?
Cheers Dave
i have one u can have supposta be good but i would have it hecked first 4 free come and get it
u2u sent greedy
u2u 2 u 2 t2 ha ha love it
does that mean it has a higher top speed with less revs if i went for a t3 box?
No, the gear box with the 3.88 R&P has a lower top gear to make up for the higher R&P, so it is about the same, 1st 2nd and 3rd are a bit taller, as
they are the same ratios as the 4.125 R&P gearbox.
Hope that makes sence!
sort of makes sense , well doesnt matter anyway , thanks greedy a free L bug box :beer
