WTD Inlet Manifold 1974 LBUG 1600
Kever - February 14th, 2006 at 04:55 PM
Looking for an Inlet Manifold to suit my 1974 L Bug 1600cc.
Has the single preheater pickup. Has a small vacuum outlet to the left leading to the Air Cleaner.
If you have one that is not blocked or rusted out .. and for a reasonable cost :) please let me know.
Many Thanks
Robert
Melbourne
killakornkobb - February 14th, 2006 at 07:00 PM
single or twin port? i think i have what your after, in melb also
Kever - February 14th, 2006 at 07:20 PM
Hi Damien,
Thanks for the reply,
My Bug is a Twin Port.
Regards
Robert
killakornkobb - February 14th, 2006 at 07:46 PM
i got the manifolds to suite a 1600 twin port, all good except one heat riser is rusted out. also got the carb i was running on the manifolds too
killakornkobb - February 14th, 2006 at 07:53 PM
my bad - i had a look outside, it seems when i had my manifolds changed to fit my weber, my mate ground thru the heat risers.. and theyre not seperate pieces like on the manifold for the weber:(
sorry pal, thought i had what u were after
Kever - February 14th, 2006 at 08:05 PM
Thanks for looking Damien :)
Robert
beerdoc - February 14th, 2006 at 09:05 PM
Let me check the garage
Give me a couple of days
Kever - February 15th, 2006 at 03:03 PM
Thanks DOC :)
Are there any other possibilities should DOC not have one?
Robert
beerdoc - February 21st, 2006 at 08:36 PM
Have failed you but have not exhausted all avenues
If you still needing I will keep looking
Craig Torrens - February 21st, 2006 at 09:08 PM
I have one but I am located in Sydney.
