splitty front end
quazi - June 18th, 2006 at 12:52 PM
Just took out my type 2 splitty front end,out of a 57
as is $100 comes complete right to the hubs.
Thanks shane,melbourne.0402255551
bajachris88 - June 18th, 2006 at 01:20 PM
rekon u could weld it to a bay front?
t2 - June 18th, 2006 at 07:41 PM
not to sure what you want to do but a bay front end is ball joint and depending on the year usually runs discs , you would be better of keeping a bay front end in a bay as they will all be able to run discs without any hassals
the split link pin beams will need modified shock towers to fit into a bay seems to be a step backwards to me, but as i said not sure what your plans are
