Pulled this out of a driving but rusty 74 has auto flywheel does have one sparkplug cross threaded all complete $175..Good auto to suit $90
Located coffs harbour
u2u or email
Probably a stupid question, how hard is it to stick one of these into a beetle?
is this still available?
+ wats the solution to a cross threaded spark plug?
[ Edited on 29/10/2006 by bajachris88 ]
depends, there are quick fixes and long term fixes.
short term - helicoil
long term- could retap it for the next size up spark plug?
still forsale..bump
Ray would the auto be the same as the one in my vanagon? Regards mitchell
Is your Vanagon watercooled or aircooled?
There are two different auto transaxles used in bay Kombi's... the later and better one, is the same as the one used in the aircooled Vanagon.
I presume that Ray's one would be the earlier type... possibly still compatible if you swapped a few things round and made modifications to the
throttle linkage (totally different setups... late cable is run via the gearbox), but indications are that the early box is hard as hell to get parts
for so is a poor candidate for a rebuild if it was ever needed. It also has rather crappy gearing in comparison to the late one if I recall...
I am not 100% sure but I think thew watercooled Vanagon has a different auto transaxle altogether... try asking Menangler as his wife drives a
watercooled auto Caravelle. ![]()
Cheers!
[ Edited on 7-11-2006 by Schmoburger ]
this gearbox still for sale?
Gearbox still here
did you drive with the auto ?did it select all gears ok?is flex plate and torque converter included? ,cheers ,Jack.
