before i bugger around making a manafold for this thing i better see if someone just has one lying around.
i need an individual runner style manafold for a twin throat holley bug spray. i think zenith and the DCN-14/DCNF webbers use the same manafold as
well.
needs to be for a single port engine.
Nick
spewin
i had a bug spray and a single port manifold that i threw in the bin coz i thought it would never get used :cry
i wrecked the carb tho but manifold was good
good luck dude
not to many ppl like the old holleys so there arnt to many kickin around anymore
i put up a post asking for the carbie and someone told me they gave one away on the weekend.
now ive got the carbie and i ask for a manafold and you threw one away ha ha.
am i the only one who keeps everything?:jesus
bump
hehehe - the one i gave away came with a chrome manifold in real good nick - universal for either twin or single port lol....
the carbs still go for $50usd on samba.. . crazy...
nick
[ Edited on 31-10-2006 by bond ]
is there a big difference in twin and single in these manifolds as i have a twin port one for a weber prog
ive got a twin port manafold 2.
the problem is it doesnt have heat risers or a bracket to stop the manfold from just rocking back on the boots if u depress the accellerator.
also the end peieces for SP heads to use one of these manafols are 130 bucks.
i really want a 1 peice single port manfold like the edelbrock individual runner u always see in the old books. i know they are around.
if i cant find one ill make one.
not a problem i thought id ask. mine had a bracket that went from one of the carb bolts down to the fuel pump bolt to brace it
thats cool.
how are you anyway barls?
the stock manafold has that little brace to the case behind the fuel pump.
ive also seen manafolds that cover the fuel pump stand and u then use an electric pump.
im good mate only been home for 2 days now. i think ive still got a photo of the weber installed some where let me have a look.
hows the bugs going btw
pretty good. still sorting out problems but its running pretty good right now.
