I have a full set of late type 3 chrome trim strips which go on the waistline, and rockers on the sides of the car. You can have the set for $30...
I also have a late drivers side mirror for type 3, $20.
Ren,
got any idea what postage would be to Brisbane (4306 postcode) and how you could post them without bending? (Post tube?)
Next in queue. What years Ren? Is it the thinner side moulding?
Brad
that's right Brad, it's the later thin type, for, I think 68 on? definitely 69-73 anyway.
Don't think I'll be able to post them due to AusPost length restrictions. I could put them in a post tube otherwise. You're first in line due to
that problem, 65Busser.
I'll have them at DOVW if they don't sell here, so any interstaters can pick them up there.
They are in pretty good nick too.:blah
Thanks Ren. I need the wider trim. I suspected they'd be the thin one but I had to ask the question.
Brad
yes these are the later thinner type...
So the main side trim would be thin and the two at the bottom of the sides would be wide?
Am still interested even if they can't be posted, maybe able to get them held by a Melb person till I get down there (if I miss DoVW)
As long as it's under 105cm long, you're fine. But i guess the rear guard strip would be close to that length...
yes the rear would be clearly longer than that. I'll measure it today, and yes Penguin the bottom pieces that go along the rockers are wider, but not as wide as early type 3's. Will let you know if I can send them or not.:thumb
Cheers,
my set is a wee bit dinged etc. If I postable great, if not, I do have means and ways
(=a sister in melb
ok well 'sister in melb' plan sounds like a winner, otherwise i'll see what the post can do for me...
Cool,
sorry wasn't wacthing this thread for a few days. What we doing
