FS: shed contents - i was too lazy for shootout
amazeer - November 5th, 2006 at 05:51 PM
indicator switches. one from a 78 kombi, one from 74 type 3. $20 each
late kombi clutch cable $10
3 x type 4 alternators $10 each or 3 for $25 [pending pickup-fish]
3 12V starters unkown origin and condition $5 each
kombi EFI throttle body, bored out 5mm, extended shaft for TPS $10 [pending payment-bus914]
2 x 2 litre cranks $50 each [wayne]
1 late kombi wheel and tyre freebie
1 steering column and indicator switch to suit oval freebie [lohoon]
2 x mint narrow chrome strips for type 3 $20 each or the 2 for $30
intercooler, approx 300mm square, tapered end tanks with elec fan $75
KKK turbo as fitted to the new beetle etc. Retro fitted with sigma wastegate as VW one shit itself in first month of its life $100
aluminium quicksteer. Cost me something like $200, $50 for you
Hall effect distibutor Cost me $230 10 years ago, yours for $40.
IRS pan as described elsewhere $1000 http://forums.aussieveedubbers.com/viewtopic.php?tid=56465#pid544526
All located in Warilla NSW 2528
F'n bargains that I just cant fit in storage while new house is built.
[ Edited on 11-11-2006 by amazeer ]
bond - November 5th, 2006 at 07:01 PM
u2u - quicksteer, hall dizzy
ta nick
[ Edited on 5-11-2006 by bond ]
ColumBUS - November 5th, 2006 at 07:06 PM
if any or all of the alternators work i'll take them, as well as the dash pad... will call ya asap
pod - November 5th, 2006 at 07:07 PM
hey fishman if you take them all i`ll get one of you if it fits my bus:spin:
Takhoal - November 5th, 2006 at 07:46 PM
heater box, t4? what side and by heaterbox you mean the whole setup or just casing?
ta
amazeer - November 5th, 2006 at 08:00 PM
for you fishman the price is $25 + a schooner at shellharbour pub one evening.
amazeer - November 5th, 2006 at 08:03 PM
left side complete heater box for type 4 engined kombi
[ Edited on 5-11-2006 by amazeer ]
Takhoal - November 5th, 2006 at 09:41 PM
will drop u u2u 2moro re heaterbox.
amazeer - November 5th, 2006 at 10:35 PM
In answer to FAQ, I go to the post office almost every day so I am happy to post anywhere for the cost of postage.
Cost of postage = what is calculated at auspost.com.au + cost of any special packaging if needed.
h - November 5th, 2006 at 11:56 PM
hey amazeer im interested in the oval indicator stork/switch thingy.. if no one has put a dib on it..
how do we go about having it psoted to us like $$ wise to you i mean..
U2U me about it would be best pls..
cheers paul
vwkid - November 6th, 2006 at 04:09 PM
what is an aluminium quicksteer?
type3lover - November 6th, 2006 at 04:56 PM
I'll put dibs on the turbo and intercooler.
U2U sent
76camper - November 6th, 2006 at 05:27 PM
Is the hall effect dizzy a 009 or sva?
1916 - November 6th, 2006 at 06:18 PM
whats the deal with the quicksteeR?
bus914 - November 6th, 2006 at 06:30 PM
kombi EFI throttle body, bored out 5mm, extended shaft for TPS $10 - U2U sent
amazeer - November 6th, 2006 at 06:53 PM
A quicksteer is many things. Increases longevity, boosts sexual performance, helps you give up smoking and lose weight.
As an interesting side effect though, it attaches to your steering as seen in the picture (bolts supplied) and your tie rod ends then connect to it. This increases the length (see) and reduces steering input by about 30%. So you actually a) have to turn the wheel less and b) can catch a slide with opposite lock in 60% of the time it took you before. in theory. you still need the talent to pull it off. I make no claim that this will turn you into an Ari Vartenan. I recomend you clean your steering arm though because I now have a greasy phone.
amazeer - November 6th, 2006 at 06:58 PM
The dizzy started life as a SVA part number 0 231 181 005 what is that from? i dont know.
At the time I had it done, i had to send it to QLD, the shaft was machined to take the hall effect gizzards and the advance mechanism was locked. It still has the vacuum can on the side of it, that is simply to cover the hole. You would ONLY use it if you have an EFI system which also controls ignition timing, eg Haltech E6.
tdegens - November 6th, 2006 at 09:24 PM
I'll take the t3 windscreens and the rear fastback seal and the 2 paper heating tubes for the kombi. can I come and pick them up on sunday? What are the stone trays? If they are the trays under the front I will take them as these will be great..
Cheers Tom
amazeer - November 6th, 2006 at 10:46 PM
yes you may come and get.... but Sunday I will be officiating at Huntley Hillclimb. You could pick up from there if you like.
Volkswagenboy - November 7th, 2006 at 12:05 AM
Quicksteer- Does it only fit beam front ends?
-Staggers.
amazeer - November 7th, 2006 at 08:15 AM
hmmm, it would fit and work on anything with a steering box, so long as the spacing of the tie rod end holes is the same.
tdegens - November 7th, 2006 at 08:43 AM
How do we get to the huntley hill climb?
Cheers tom
tdegens - November 7th, 2006 at 08:47 AM
Also can I take the rear boot seal? Do you have a front window seal for a fasty floating around?Willl see you sunday 11 ish or so. Can you U2u me your number or how can I recognise you at the hillclimb?
Cheers tom
amazeer - November 8th, 2006 at 08:12 AM
huntley directions http://wscc.org.au/FAQ.html#how%20do%20i%20get%20there
I will be in the timing shed most of the day. Will be the one wearing the green WSCC polo shirt. Just duck under the fence and come on over.
tdegens - November 8th, 2006 at 09:29 AM
See you there.
cheers tom
sinecure - November 8th, 2006 at 11:22 AM
Second dibs on the turbo, please. Couple 'o' questions.
What model KKK? Did you use it? What's it like? Much play in the shaft?
Cheers,
Mick.
[ Edited on 8-11-2006 by sinecure ]
amazeer - November 8th, 2006 at 11:58 AM
I dont know off hand what model it is. Will look when I get home. Its the one that I believe is fitted to all of new beetle/golf/A3. It was a warranty job that was replaced only a few months old. The wastegate actuator rod broke off the diaphragm. I replaced the diaphragm with one from a sigma that I had lying around.
I used it for a short time a couple of months on an otherwise stock 2litre kombi. It worked really well. Worked well up until I overloaded my kombi and melted the heads off it on that fateful trip to valla. Worked so well that even after the first head melted at Kempsey I still travelled at the speed limit until the second head melted.
While those heads are rooted the turbo is still in as new condition. The wheels are unmarked, there is no end float. I'll take some detail pics of it tonight.
mat54 - November 8th, 2006 at 02:59 PM
hi there
would be interested in the oval steering and indi switch if still there
thanks
mat54
am in perth
chers
amazeer - November 8th, 2006 at 07:20 PM
The oval steering cloumn has a queue for it. Switch has been claimed
I've taken some pics of the turbo, the best I can do. In the last shot, the stainless steel lines coming out of it are for water connection. You can pump water through it to cool it but its not essential. It just helps to stop morons from hooning around and shutting the engine down without letting it cool. banjo fitting on the other side is threaded and for the oil connection obviously. Oil on the other side is taken out with a flange and tube. I'll toss that in as well but the buyer will probably want to make another to suit their application. I'll also toss in the exhaust flanges and as much pipework that will fit in the box.
[ Edited on 8-11-2006 by amazeer ]
amazeer - November 8th, 2006 at 07:42 PM
managed to get a reasonably good shot up the exhaust. Looks like I was running a bit rich.
one very similar just sold on ebay for $155. http://tinyurl.com/tyepb
Thats where this one will go next week.... so hurry up ;)
