This is a Wizzard Roadsters (UK) Split window beetle kit. I purchased it years ago & have never got around to using it.
It will fit all big rear window beetles
You get the following:
1 x outer skin
1 x inner skin
2 x window glass
2 x window seals
As per the instructions on installation: ( basic version) you cut straight down from the bottom corners of you rear window, then cut across the back
of the car just below the rear air vents. Fit up window kit inner & outer, then bond into place.
Price: $400 ono ( cost me more than that when I bought it & shipped it too Aust)
Email: fdunleav@bigpond.net.au
Ph: 0433605221 (5pm - 10pm / 7days)
cheers :thumb
[ Edited on 22-12-2006 by 57 Cal look ]
Thanks :kiss
will this fit ovals too?
To fit it to an oval you could cut the center "split" part from that kit and fiber glass/bog it into the center of the oval. That way there is no
cutting to the oval bug and it could b changed back to standard easily. Its not something i would do to a nice oval tho.
Alex.
The oval window has different outer edges to the split too....the split goes to more of a point...
Also the oval window is bigger so the glass wouldn't fit. Ovals with the centre oillar look odd. best of cuttinf the whole lot out and fitting the
whole piece.
T54
bump
Sam you can have the centre piece out of the split I've modified to an oval. much better on visability now than having that bar in the way.
