Alloy V8 engine with Vw adaptor & irs kombi box
TheMiniMan - January 2nd, 2007 at 11:13 PM
For sale--> fully over-hauled Leyland P76 4.4 litre power unit, Re-ground, hardened & balanced crank with new big ends & mains, thrusts etc, new road hot cam, new holden anti-pump up lifters, 20thou re-bore with JP pistons & JP double row adjustable timing gear kit, heads overhauld with un-leaded inserts, new guides etc, new gaskets & seals throughout new water pump, new, new new, New,,,this engine has done about 2kms of driving, it`s brand spanking New!!!
comes with VW gearbox adaptor plate/flywheel/conversion & late kombie IRS gearbox.
Has Rover 3500 tappet covers & i`ve also pollished the inlet manifold (yeah don`t ask how long that took me) can hear running, complete with carb , dizzy, manifolds, enging mounts & crossmember,,, basically everything you need to stick it into your kombie.
this whole package cost well over $5000 to have ready to go
will sell it for $2000 cash.
no mucking around, no offers, come & grab it.
first in best dressed.
Ph mobile 0407 135 656
Brisbane, near Gateway bridge.
seagull - January 3rd, 2007 at 02:09 AM
why did you remove it ?
TheMiniMan - January 3rd, 2007 at 07:37 PM
Seagull, i had an alloy V8 in the back of my splitty ute for nearly 20 years , 4 wheel disc brakes, twin fuel tanks, etc etc etc--->
http://madmatt.bigblog.com.au/data/1/8412/image/V8CombieMoretonIs392502006090...
& the Dept Of Tpt ended up wanting it off the road, so,,,i put it all into a Rivmaster off-road racing frame Buggy --->
http://madmatt.bigblog.com.au/data/1/8412/image/buggyjump12959420070103192601...
& raced that for about 4 years till my back couldn`t take it any longer ,then sold the buggy (minus the power plant) to an Airforce pilot at Amberley... i re-built the whole engine & shoved it into a motorkhana special --->
http://madmatt.bigblog.com.au/data/1/8412/image/mrbug5949620060626144038.jpg
but it only ran up the road & back, it was just insane to drive, my mates called it "whiplash" cause that`s what you got every gear change :-) so i ripped it out of that thing & gave the frame to a mate of mine to fit a mini motor into it & teach his kids how to drive,,, so the whole power unit, gearbox & adaptor assy is sitting here, all done up, like brand new, ready to fit into VW-whateva,,, just that i don`t have that "VW-whateva" anymore... I sold all my Splitty stuff (except i still have a steering box & a few wide wheels left)
so,,, this is just sitting here taking up space where i can put my new buggy--->
http://madmatt.bigblog.com.au/data/1/8412/image/R1Buggy022305820061228231818.jpg
I was thinking about turning the box upsidedown & building an open wheeler frame for it to go hillclimbing as i also have a full set of turbo manifolds made ready & the T4 turbo fully overhauled sitting here that could go onto it as well,,, but i have way too many projects allready,
so it`s got to go,,, & it is totally spanking, i really has only gone up the driveway & 100 yards down the road maybe 3 times max,,, that`s as far as it`s driven from new... there`s a heavy duty clutch pressure plate & copper puck plate with it as well.
david777 - January 3rd, 2007 at 08:31 PM
calling Pete Wood... this is the motor you need for your motorkhana special !!
bond - January 3rd, 2007 at 08:48 PM
that first pic under the split ute is unreal!!!
love it
nick
TheMiniMan - January 4th, 2007 at 12:37 PM
Bond,,, My girlfriend took that pic while i was trying to repair a brake hose that split after i smashed into a big motha log at Moreton Island, got a flat tyre & bent the right front riim & bent the steering tie rod all in one hit, hence why the small wheels are on the front. Normally had the 9.5R15s on the front with those huge 12R15s on the back.
I have a pair of 9.5R13" sand wheels & tyres here for sale too if anyone is interested,,, along with 2 kombi offset sunraisiers & 2 beetle offset ones as well, all 6 wheels & tyres for $100,,, come & grab em better that someone gets some use out of them than just sitting here taking up space.
brisbane ph 0407 135 656
kevo - January 4th, 2007 at 09:32 PM
i cant believe you are selling this now, if it was a year ago i would have bought it in an instant!
it cost me just over $2000 to completely rebuild my 3.5 V8, let alone the cost of the conversion kit and geaRBOX!!!!!!!!!!!!!!!
im so tempted to buy this,
damn that is a good price mate!
TheMiniMan - January 4th, 2007 at 11:35 PM
yeah i know, thanks Kevo,,, I really just havn`t got the room & i can`t see me doing another kombi V8 for some time as i`ve got my new yamy R1 powered buggy on the go & am in the middle of building 3 new race minis, so this just has to go.
I can put onto a pallat & wire/rope/tape it all down & whack onto a courier/truck/van of your choice at buyers expense.
The funnyest thing about this conversion was when i did it the first time (about 26 years ago) was that it took just over an hour & the V-dub motor was out & the V8 was in & running.
anyways, transport to anywhere in Oz shouldn`t be too hard to orgainise & i have had 2 calls on it so far, so there are people thinking about it, fingers crossed that someone will get to feel the grunt that this thing produces... better get your brakes up to scratch tho :-)
It truely has only gone down the street a couple of times & that`s it
:-( I really don`t want to sell it, but it`s in the way,,, i can definately use the money on my buggy,,, & it would be even sadder to leave it sit & not get used.
[ Edited on 4-1-2007 by TheMiniMan ]
TheMiniMan - January 4th, 2007 at 11:43 PM
Besides,,, i`ve got another one of these alloy V8s, T4 turbo charged in the front of one of my race minis :-)
serious!!! & still front wheel drive to :-)
http://www.miniman.com.au/black.htm
http://www.users.bigpond.net.au/TheMiniMan/WebPage8/BlackMagictyrbo@home02.jpg
http://www.users.bigpond.net.au/TheMiniMan/WebPage8/BlackMagicTurbo@home01.jpg
soooo,,, as you can see,,, i`ll have my hands pretty full with alloy V8 power even without the kombi V8 :-)
TheMiniMan - January 6th, 2007 at 10:59 PM
Ok,,, who`s keen now if i said i`d drop the price to $1800,,, just so it helps a bit with shipping/freighting the thing??????
Surely someone will want "Decent" grunt in their Zombie, Surely???
$1800
ph me, you know you want to......
don`t have to tell the misses, just do it & say it followed you home :-)
I used to love draggin off commodores & wheel standing past them at traffic lights in my splitty Ute :-)
kevo - January 8th, 2007 at 05:35 PM
i would love to buy it if its still for sale in a 6 weeks or so for sure!
not to replace the new 3.5, but for another kombi, then i could have an everyday v8 kombi and a bulls**t faszt street weekender v8 kombi, $1800 is Too good to be true i just dont got ne cash to spend right now hey, sorry mate
Volkswagenboy - January 8th, 2007 at 08:07 PM
4.4 you say? It'd be a good upgrade for my Land Rover. ;)
Good luck with the sale.
-Staggers.
TheMiniMan - January 9th, 2007 at 05:08 PM
Thanks Volkswagenboy,. it is a good upgrade for any car really.
I`m getting pretty desperit , anyone even half keen might want to ring me pretty soon otherwise i`ll just have to buy another kombie to put it in myself :-)
Common, $1800 is pigeon feed for this ,,,
TheMiniMan - January 15th, 2007 at 09:58 PM
Ok,,, i`ll take $1700,,, this just has to go
I`ve got lack of room problems & i can`t see me getting another kombi ute to shove it into for years & i really need the money now too
It even comes with a fully over hauled starter motor
what`s wrong with you lot??? Don`t you like doin wheel stands? :-)
are you scared of real grunt under you right foot? :-)
who wants an absolute weapon at an absolute bargain???? Dam the engine cost more than twice that just to have overhauled , flowed, balanced, new pistons & rings, bearings, new JP double row timing gears & chain, etc etc etc etc etc etc& it`s barely turned a kilometer or 2 since then, it`s truely brand spanking, & bullet proof. My familly were the Brisbane Leyland distributors back in the day, this is a dam good donk, make no mistake!!! & it is my own personal motor, not just something i`ve trown together. crickey!!!!
whoever buys this is going to laugh at all you guys for not buying it,,, it`s such good value,,, you will all kick yourselves for not grabbing it.
guru - January 17th, 2007 at 01:29 PM
you have u2u
TheMiniMan - January 17th, 2007 at 11:19 PM
sorry about the delays with the u2u thing,,, i`m a dork & didn`t even see/know that they were there,,, all enquiries have been attended to now :-(
my bad,,, sorry
ph me if you`d like more info 0407 135 656
cheers & thanks for the responses
Matt
DubCrazy - January 18th, 2007 at 08:37 PM
heya mate, as the 2.0 exploded in the kombi i am in the market for a new engine... you say it has pretty much everything i need to fit, does it inclued radiator,exhaust etc etc,
thanks
steff....................
TheMiniMan - January 18th, 2007 at 10:07 PM
i do have a range rover one here that`s been modded to lie flat under the car & you`re welcome to it if you buy the donk & i have the old exhaust that i used on my Zombie Ute & you`re welcome to it also, but you might want to have another couple of mufflers added for your neighbours sanity sake. no pipes to plumb the water tho, you`ll have to sort some stuff like that, but i can help with info of how i did things easy-peasy, it`s not hard at all, just a little bit of time & you`re away.
guru - January 18th, 2007 at 10:42 PM
secret squiril u2u
TheMiniMan - January 18th, 2007 at 10:49 PM
hee hee,,, lots of secret squirell u2us goin on now :-)
KruizinKombi - January 19th, 2007 at 07:29 AM
If I had the money right now, it would already be gone. I'd even drive up to pick it up. Pity you're in a hurry to sell it. :smirk:
TheMiniMan - January 21st, 2007 at 09:06 AM
yeah i am in a hurry Kruzin Kol, the shed is getting cleaned out & some new concreat is happening & then a whole heap of shelves are being made up, i have crap everywhere
I do have a few guys interested & we`re talking , The price is definate now, not going any lower, it`s allready gone way way too low now, i`m going to cry when this goes. But i really do need the room & i really REALLY need the money now too. :-(
newoldmanx - February 21st, 2007 at 03:42 PM
i guess this sold yonks ago?????
4agzekombi - February 21st, 2007 at 03:48 PM
Um yeah, should have posted.
I bought this and am soon to have a nice V8 powered buggy
Sam
newoldmanx - February 22nd, 2007 at 10:20 AM
well done great buy
i was actually looking at it for my twin cab
but decided to go h6 subie(noone does old school leyland stuff in fiji) ill be very interested to see how it goes in a buggy what g/box trye combo are you thinking of???
