Hi Everyone,
I am looking for some parts for a 72 S Bug.
I need the wiring going from the steering column to the switches (it needs to be the 4 spoke steering wheel type of wiring).
Also looking for the little box (off white colour) in the engine bay that they used to plug a computer in to check the system and lastly, an air
cleaner for the 72 model. It has only 1 breather coming out of the drivers side of it.
I am in Brisbane and can pick it up anywhere here, will pay for freight from elsewhere as well as the cost of the parts.
Yogie
ive got a few firewall diagnosis plugs around
none of them still have all the connectors in them tho
only the plastic plug part left
is that what u need?
-Joel
I have the connectors in mine. It is the cover that has broken off and is taped on. If you have one of the plastics parts in good nick, let me know
hopw much you want for it.
Yogie
ill give my old man a call about the rest when he goes back on monday as he has access to my other bug which has been wrote off. its a 72 sbug to boot as well
Thanks Barls
Yogie
ah ok all the flap door things are broken off on mine too sorry
they sun coming in thro the decklid vents is pretty harsh on them after 30+years
only thing worth trying is one out of a bay kombi
they are well protected behind the doggy door and dont get any sun
they are the same plug
Joel
Cool. Thanks for that Joel.
Yogie
ok ive talked to the old man and since he wound be the one pulling it out i think its best if you give him a call at work and have a chat so we can get the right parts out of it. his number is 02 65523190 and his name is les he should answer
The diagnosis plug is the same as on a bay window Kombi, they may be less weather affected as they are in the engine bay.
Personally I would remove the wiring and chuck the plug in the bin.
Thanks for that Barls and Steve. I will call him today.
Brett.
