1916 CC ENGINE
RodPenrose - February 25th, 2007 at 09:17 AM
I have all the major components to build a realy fast 1916 engine that consists of the following parts ,
Street eliminator heads , ported , 42mm x 37.5 mm stainless valves , dual springs with dampeners and matched IDF/DHLA intakes
low milage Brazillian case , std tunnel , 94mm bore
new CB 69mm cro-moly crank
new Scat I beam conrods with 3/8 bolts
new engle 130 cam and gear
new Scat solid lifters
used 94mm pistons , new rings , new barrells
full set of bearings
german gasket kit with rear main seal
for the bargain price of $ 2850 . I also have carbs and other parts to complete this deal , thanks ROD , 02-42729920.
humpty - February 25th, 2007 at 10:13 PM
Bloody hell.... Another one!
