I am geting more interest on the 914 in stock form so I might pull the ej20tt and the modified subaru 5 speed and sell them. It is a 96 gt liberty
motor that was bench run prior to purchase with about 70k on it, they are set up as a midmount and come with a full harness, computer and performance
clutch. Also custom box and engine mounts and shifter linkage set up.Perfect for a spyder formula v or kombi mid mount conversion....or a bug if
creative. $2000 ono
matt 0416 115 993
? please Matt
metal head gaskets ?
what injectors ?
gear box code ?
cheers seagull
Ill check it out and let you know..
How did you go with modifying the sport matic porsche box?
Matt
Quick question.
How would one of these engines go in an 'AUTO' 77 Microbus?
Not sure how the 2lt auto gearbox would handle the power from the ej20tt engine.
I've been thinking about a Subaru conversion for the power and fuel milage for a while now but have been worried about the auto gearbox.
The mods will work , I have the box here on the shelf just need to get the out put shaft machined
Quote: |
