I have the following engine kit for sale with all components being brand new and of the highest quality . This is a serious engine and will make big
power ,
CB aluminium high roof case , opened for 94mm , clearanced for 88 mm , solid #3 cyl , 6 shuffle pins , +9.5mm deck with 10mm inserts
88mm flanged crank , type 1 mains with type 4 centre , chevy jnl , with forged cro-moly flywheel to suit single or dual disc
fk 7 camshaft , clearanced
steel straight cut gears
5.5'' H beam conrods with arp 2000 bolts
10mm cro-moly head stud kit
scat solid lifters
94mm piston/barrel kit
superflo heads with 42 x 37.5 mm stainless valves , dual springs , rocker covers and idf intakes
full set of bearings including centre main bearing
scat 1.4 pro rockers
jay cee racing pushrod tubes
cro-moly pushrods
30mm oil pump with filter
009 dizzy
crank install kit
case install kit
gasket kit
all for the bargain price of $ 6700 . Shipping Aust wide is available and assembly of this kit will be an extra $ 450 , ROD , 02-42729920
How would you feed this monster????
Berg 51 Ida's
estmated HP ?
LOTS:P
As a new member could someone tell me if this engine would suit a 60 split panelvan.
Brian
This thing would fly
