2332cc engine
RodPenrose - July 19th, 2007 at 08:28 AM
I have the following brand new components to build a 2332 cc engine that will suit a type 1 , early type 2 or any type 3 ,
magnesiun case , opened and clearanced { 84 x 94 }
4130 cro-moly crank , 84mm , chevy jnl
cro-moly lightened flywheel
H beam conrods , 5.5'' , chevy jnl
Engle fk 8 camshaft and gear
Scat lifters
Full set of bearings
26mm oil pump
1.5 qrt deep sump
8mm cro-moly head stud kit
94mm piston/barrel kit
42mm x 37.5mm stainless valves and dual springs
cro-moly pushrods
1.4 ratio rockers
bolt on valve covers
double o ringed push rod tubes
aluminium degree pulley
all for the bargain price of $ 4400 . there are only 2 of these engine kits at this price , ROD , 02-42729920
maximilian - April 8th, 2008 at 09:48 PM
What would be a rough power figure for this bad boy, approx. ??
