WTD 4 Stud Type3 rear flanges
11CAB - August 19th, 2007 at 04:40 PM
Any leads?
Graham
flipflopsurfer - August 22nd, 2007 at 04:44 PM
If I can find some wide 5 rear drums for my bus, you're welcome to mine.
vw54 - August 22nd, 2007 at 04:50 PM
Vintage have new ones give them a call 02-9789-1777
Joel - August 22nd, 2007 at 07:39 PM
if u have no luck i have a set here they have the 5x130 porsche pattern drilled in as well as 4x130 but thats not a problem if ur just using standard 4 stud vw
-Joel
vw54 - August 22nd, 2007 at 10:11 PM
The ones from Vintage are blank no stud holes so take yr pick if you want another PCD
dangerous - August 23rd, 2007 at 03:08 PM
You can turn down a beetle 4 stud drum if you find no type 3 flanges.
This may be the most affordable option.
GASBNR - August 23rd, 2007 at 04:13 PM
I know I a guy here in mebourne who has a stack of them, I think.
11CAB - August 23rd, 2007 at 05:49 PM
The Type3 flanges have a lip on then that I will use to help locate a VN rotor to. I had a look at the 4stud drum and they dont have that lip.
11CAB - August 23rd, 2007 at 05:50 PM
No reply to email, any idea on cost?
vw54 - August 23rd, 2007 at 06:06 PM
they must be busy I just gave them a call 4 u
Undrilled $85 each
