Chasing a pair of Rossi sealed beam headlights for my notch, if anyone can help that'd be great.
Rhett.
what condition (are these the ones that got the blinkers in them) I got a real ratty set few parts missing
Those are early ones, late ones look pretty much like stock lights. thanks tho.
The purpose is to have sealed beam lights on my notch, I have one, I'll dig it out and take a pic.
Hi,
I have only ever seen the H4 conversion which are not strictly a sealed beam.
You can put type one golf headlights into the headlight bowls, after you have installed some tabs to self tapping screw the mounts to.
Then you can buy 75 76 Beetle headlight surrounds to trim them off. You will need to remove the chrome trims to adjust the beams. You may be lucky and
your bowls will already have tabs in them.
Cheers,
David
