Looking for a cheep reasonable Nut to Nut gearbox out of a splitbus with the reduction boxers to suit my off road buggy.
I know, I know there are better boxes but this is not a road car and the lower gearing is what I want and axle tramp will not be an issue with my
application.
Brett
36 or 40 hp or big nut
somethin to think about if u have a 12 vlt flywheel
have above but not 40 hp
email for more info. Qld though...
Ok I plan to run a 1600cc motor, can you mod the bell housing to fit the larger fly wheel, I have done it on a 1300 beetle gearbox to suit a 1600
flywheel.
I surpose the other option is to fit a 1300 flywheel to my 1600 motor, is that possible?
Failing all that what gearbox (year model, part number) should I be looking for.
Brett
yes and
yes failing that
and gat bignutter made for 1500
are u Qld as i have 0ne
