Hello all
I am looking to buy some good condition heater box's for an upright 1600 single port engine (does anyone know if singelport ones are different to
dual port ones). Prefer melbourne area
Cheers Paul
The later dual port boxes dont have the alloy center section so there lighter and woont conduct as much heat as the early ones which have the ally
center section
Type 3 arediffernt again as the heater cable pulls from the top instead of the lower area
I'mpretty sure I can help, will have to check stock when I return to work.
Call Sasha at DELUX on 0425 758 518 after the 7/01.
Aitor at volkswreck has a good supply of them. 9555 6770
Cheers All
Will follow up
Paul
