I have enough parts laying around to build a very fast engine that would be suitable for a drag racing application . The following parts are all new
and are of the highest quality ,
CB aluminium highroof case , clearanced , bored , solid # 3 cyl , 6 shuffle pins , full flowed and universal
Demello full circle 82mm wedgmated crank with lightened flywheel , vw jnl , std/std
Pauter 5.7'' aluminium conrods with cro-moly caps in vw jnl
AA forged 94mm racing piston and long cyl kit
Comp eliminator heads 44 x 38 chevy springs with cnc chambers
Engle fk 89 camshaft
Steel straight cut gears
Scat lifters
Shadek full flow oil pump
all for the bargain price of $ 5300 . This engine with lots of compression will produce well over 200 hp , ROD , 02-42729920
