Vehicle is Super Beetle 1971
Part required is adapter that screws onto top of washer bottle for the washer hose to plumb onto. (old one has barb to hose snapped off)
I have searched parts suppliers books and can't find it.
There used to be a couple of late beetles at Centre Rd. wreckers, though they were getting pretty well picked over -never know yr. luck, though.
Centre Road Wreckers
1602 Centre Rd
Springvale, VIC 3171
Mon-Fri 8:30am- 5:00pm
Sat-Sun 9:00am- 4:00pm
Tel: (03) 9547-7377
Fax: (03) 9547-7955
hth
Is this the part you need letme know and i will post it to you cheers shane.
Sorry about the size of the picture i had the camera set wrong,Anyway you should get the idea??????
Its a better idea to do an electric washer pump conversion. Like here http://www.clubvw.org.au/how_to_modify_those_windscreen_w.htm
I have one as well if you want it
The part I need is the small end of the setup you guys have pictured.
Bizarre, your picture shows the hose ending, with no valve end attachment, it is the bit at the small end I need.
vwmad, the picture you show is what I have exactly now. The barb of the valve end is still in the hose, but it is snapped off the actual threaded part
that goes onto the air valve.
It must be common for them to snap with age and stuff going into the luggage compartment.
