Updating my single port 1600 in my lowlight resto to a new mexican 1600 DP and need the full gammut of tinware
Anyone nearby got a set lying around that they no longer need - happy to take it off your hands or pay a small fee for this service
I will need it all, including the fan that goes with the doghouse cooling tin (apparently it is a bit wider than the one I already have)
Let me know if you can help, JOSH
Hey Josh,
I have some tins for over the heads,not sure about the rest.I don't have a fan though as mine has eaten two!
I'm in muswellbrook.
could help with fan housing
do u need the cooler also and fan itself as well
pls email
able to get this to u for no deli charge if i can have sp tins ovr heads pls
Thanks Lohoon - if I don't find anything closer I will get in touch next time I am heading up your way
Sorry bushed, keeping the singleport stuff as I intend to rebuild the old motor at some stage - will try to sort out the rest locally
JOSH
I got a fan housing, I assume it is for a dualport as it was a spare with a dual port engine, however i got no idea, welcome to have it, was about to throw it out. Its at my parents place though.
