Wtd 76 rear bumper bar
Casper - March 24th, 2008 at 06:09 PM
Looking for a rear bumper bar with solid rubber strip to fit 76 beetle. Even if bumper is in poor condition but rubber good I would like the solid rubber strip with or without bumper, both a bonus. thanks pam
Bizarre - March 24th, 2008 at 09:18 PM
didnt you get one from CIP??
Casper - March 25th, 2008 at 05:28 PM
I ended up buying one from Classic Vee Dub but it is not the same as the one I have on front and too short for the bumper so goodness knows what it is supposed to fit. It needs to match this one like on front.
68AutoBug - March 25th, 2008 at 10:19 PM
The US rubber strips used a rubber end piece at each end of the bumpers..
Wolfsburg Automotive will probably have them..
they have most VW rubbers made...
I know of a 76 beetle owner who [a few years ago] bought a rubber strip off a Kombi and made it fit
[cut the excess off??}
vw54 - March 26th, 2008 at 05:54 AM
If you get an origional rubber then you will need the special clips that hold it on as well these are probally harder to find than the rubbers as there a diffeerent shape to most and they have to be broken to remove an old rubber from a bumper
give vintage a call in sydney 02-9789-1777 to see if they have a rubber and clips the rubber has a metal strip in it as well which bends very easy so it wont fit the bar correctly if bent so if you get one lay it flat untill needed
If you have an after market bar from CIP then you may also find that the holes wont line up to the rubber section better of getting an origional german bar and having it repaired and re chromed
lots of luck
