FS falcon BA rims modified to fit kombi. these are 16x6.5 offset 37 and fitted very neatly under my kombi for the last six months with 245/70's at
the back and 215's at the front...they come with the dress trims which are a little scatched from going bush. $100 for the 4 rims and trims pickup
gold coast or anything else by arrangement
[img]
[/img]
bump
How are they modified to fit Kombi stud pattern??
the ford PCD is 114.3mm the Kombi is 112mm so the difference in radius of the PCD is 1.15mm. the ford uses 12mm studs, the kombi 14mm so the holes have been enlarged 2mm inwards moving the hole centres in 1mm theoretically leaving a difference of 0.15 mm....any more questions happy to answer
