new 1916cc Bottom end
RodPenrose - July 13th, 2008 at 06:54 PM
I have a brand new 1916cc bottom end here that I would like to move quick . You will get the following components in a deal that is already assembled ,
new dual relief as41 magnesium case
new 69mm cro-moly crankshaft
new cro-moly I beam conrods
new engle 110 camshaft
new steel straight cut gears
new scat solid lifters
new crank gear set
new dizzy drive
new 26mm oil pump
full set of KS bearings
all for the bargain price of $ 2200 . I can also supply all parts to complete this engine . ROD , 02-42729920 .
baybuscamperkid - July 16th, 2008 at 09:25 AM
how much with the heads, pistons etc to complete?
BUGBOY - July 17th, 2008 at 07:56 PM
Thats like asking how long is a piece of string?
I think you best give him a call and tell him what you want.
stock heads? big values? etc etc
baybuscamperkid - July 17th, 2008 at 08:12 PM
fair enough, just thought since he had listed that he can supply all parts that there may have been a specific setup that Rod was going to recommend
