WTB - Clutch cross shaft. 73 Dub - SA
herbgrinder - September 21st, 2008 at 02:18 PM
g'day guys.
Just bought a s/h gearbox for my 73 Bug and it was minus the clutch release bearing cross shaft. When I removed the cross shaft from my old gearbox,I noticed the OD of the bush end on mine is 27mm and the non bush end is 18mm,hereby lies the problem on my replacement box the ID of the bush end is 23mm and the non bush end is 14mm.would anyone have one along with the return spring that locates on the shaft?.Cheers Ron.
