Hi all.
I need a set of front backing plates for drum brakes from a US/UK spec super beetle.
Anyone have a set??
PM me
Micheal
mmm are they the same as the BJ beetle drum brakes ? Pretty sure they are but I have never pulled a Super Bug drum brake front end apart
The super beetle drum brake fronts are the same diameter as early type 3 fronts. These are a larger diameter than beetle ball joint drum fronts.
Trying to do a cheep wide 5 brake conversion/upgrade on a ball joint front end.
Micheal
yeah I got some...
Why?!
Why?
Someone in my ghia's past decided to do a frame head swap for a ball joint front end. I want to run type 3 wide five drums all round as they are
wider and a larger diameter. So to do the fronts i need super beetle backing plates. Type 3 backing plates are very different and standard beetle drum
brake backing plates are a smaller diameter.
If you have a set and they are definately larger than standard beetle 4 or 5 stud than i am interested.
mine are standard US market front drums - L Bug, 4 stud
The front drum brake backing plate from a super is 4 bolt rather than 3 bolt like other drum brake bugs.
Yep that is what i have heard. The four bolt backing plate is what i need. I will be changing the mounting holes.
Do you have any plates Steve?
I friend converted a UK 1303 over to discs and gave me the stubs and drums, I will ask him if he still has the them still but I doubt it.
Are sure that the drums are different to normal 4 stud drums? They don't look any different from memory.
im wrecking an old type 3 these are the front drums you need wide 5 with larger brakeing area let me know if you are interested....phil
also have 73 superbeetle font end only macpherson strut though any good?
Phil,
Are the fronts twin slave cylinder?
Newt
I have been told the drum braked supers had the same size drums as a early type 3.
Phil i have some drums already but may be interested in yours. How much?
Thanks for the replies all.
bump
I am sure Volksbahn had some of these backing plates.
Cheers,
David
