Up for sale is another set of 2.5 inch dropped spindles for kombi, to suit balljoint beam.
$700 firm, Pick up only from Mount Pritchard (liverpool area). Contact Geoff on 0416067932 or 9711 4383
did you make these or buy them??
i make these on a regular basis.they will widen the track 13mm per side. i make them in 50mm or 65mm drop.two sets off spindles are required to make one set.i will be looking at having them cnc machined as one piece with zero offset when time permits .
CNC ones that would be fantastic.
what about Link spindles do you do those?
If you get these cnc'd as one piece zero offset I am in for sure. You'll make a fortune as no nobody does in any where in the world as far as I know.
i dont do link spindles
I'd be another for CNC'd drop spindles. I don't want to widen the track any further as going to big discs I will need all the room I can get.
