I have a full engine kit here that I am hoping someone may need to complete their project for Warwick . i will give away a complete rebuilt set of 48
IDA's to the person that buy's this engine kit . this engine consists of the following components :
Used Mexican case bored and clearanced
New 78.4mm Welded vw crankshaft
New H Beam race rods in any length
New 94mm Piston and barell kit
Used welded and ported vw heads 42 x 37.5 dual springs
New Engle or Scat cam of your choice
New straight cut gear set
Used crank gear set
New steel cam plug
New barell deflectors
New Manton moly pushrods
New Bugpac 1.4 ratio rockers
Full set of bearings
New bearing dowells
Used 8mm head stud kit
New rear main seal
Used lightened 8 dowell flywheel
New moly gland nut
New hex relief plugs
New 103 piece engine nut kit
New Scat racing lifters
Used dizzy drive/shims/spring
New oil strainer
New lash caps
Used 30mm full flow oil pump
New Full flow oil pump cover
New gasket kit
All for the bargain price of $ 3900 . I will also supply a set of match ported intakes , a set of 48mm IDA's and a full linkage kit in with the
engine at no extra cost . All used parts have been inspected and are all good to use and I have not had time to assemble this engine , ROD ,
02-42729920 .
check mail please...
