FS nsw: ej20t (1992) compl conversion
Klaus - January 10th, 2010 at 04:22 PM
Not puttiing this in split bus so looking to move it on.
1992 legacy ej20t, 120km's, water to air int
volkconversions 228 flywheel and adapter
brand new IMI hi-torque starter for 2ltr bus box
brand new vl turbo bosch fuel pump
have had it running and driving in bus , included is all pumps rads and a/c gear(3 sets) can also chuck in a 97 wrx motor less manifold and turbo (has reco heads but bottem end needs rebuild).
Sump is not modified and has about a foot long 3inch exhaust fitted from turbo.
harness has been shortened and comes with dash cluster from subi and ofcourse the computer and all bits and pieces. only thing missing is a h/duty clutch setup.
$2500.00 Klaus 0428 427 986 wollongong. pm or call
pics if needed.
666bug - January 10th, 2010 at 05:42 PM
Hey,
can i use this setup on a super bettle and if so can you please send me some photos to thelazarusstone@hotmail.com.
thanks,
Klaus - January 10th, 2010 at 06:36 PM
if you change the flywheel and starter , or use a kombi 2ltr box in the bug.
