Chris
0432014396
Hey all. Im after a set of standard height or raised springs for my 1986 T3 transporter. Not interested in 20 year old worn out ones, but if you have
a set that was replaced in the past few years i'll be interested. thanks
front or rears. i use a company in perth who make springs at $200 each, any size or hardness you require! PS you arent after syncro springs are you? they are different!
I am replacing my twenty year worn out ones (how do springs wear out by the way) with nice new ones. You are welcome to have the old springs. no charge.
Just got a set thanks mate....thanks for the offer
beerboy, how would you feel after 20 years if you were carrying a couple of ton, all day everyday, up hill and down dale. over lumps bumps and
sleeping policemen (speed bumps)
springs go soft, and "sag", the metal fatigues and sometimes cracks (i've got some broken springs if you want to see them!) so changing them is a
good thing even if you think there are doing no more work than your drivers door.
well worn is seen as a good thing in some circles whereas broken is broken. no thanks do you want to see pictures of my nice green lowered and uprated
ones
I will have a set of worn standard ones if anyone wants them. otherwise its sims
