For a 56 oval
Indicator switch complete
Headlight switch
Wiper switch x2
Semaphore lenses
Wiper motor and arms etc complete
Door light switch (the one that clips in the door pillar, not screw on)
Wolfsburg hood badge original not repro
Front bonnet centre chrome strip
Horn button
Steering wheel (if not, i will fix mine)
Front seats? I have 60’s model seats from Camo, but if i can get original i may consider, otherwise the 60's will be fine.
1600 engine? Or complete superbug, dont mind.
Kuch (Western Syd)
PM if you have anything.
I have one semaphore arm with lens,not sure what happened to the rest,posssibly a headlight switch,wiper motor,(if it is the same as 58,not sure on
the bonnet badge and chrome strip.Old age is catching up and I can't place the difference in the bonnet badges.
Cheers Les
bump
Did you find any of this stuff grumble?
I've got a pair of repro SWF semaphores lenses if you are interested. (Not SHO / HS - so if the semaphore part number ends in A, C or E then they won't fit)
They are A
Need sunvisor and mirror too
