hey all i have for sale my brand new 2332cc engine it has
never been started it is still on the engine stand. specs
are as followed. i will be selling as complete package
NEW CB highroof Supercase. $1500
Forged CB 4340 chromoly 84mm crank. $700
CB 4340 chromoly H Beam rods. $480
AA forged pistons & longer barrels. $600
Heads 42mm inlet 37mm exhaust. $750 + Porting
Engle fk89 camshaft. $150
Steel straight cut gears. $150
48 ida webers and manifolds. $1200
Bearings. $115
Lightened flywheel bigger gland nut. $100
Kennedy stage2 pressure plate. $200
SCAT 1.25 ratio rockers. $400
30mm high volume oil pump with filter. $100
chromoly pushrods. $150
complete tin ware kit. $200
plus cost of getting engine assembled and heads ported
and eveything balanced and crankshaft was polished.
the cost of parts alone is $6795. then the cost of
everything else is over $7500.
i am asking $6000 for complete engine.
if it sells for $6000 i will throw in a close ratio swing
axel gearbox.
i can be contacted on 0405947639. cheers ben.
im located in coburg melbourne.
super deal
esp if we know what cond box is
and any axles incl? t1 or 3?
What head castings?
101 head castings.
box is in good condition and comes with T1 axels.
engine was assembled by me and a friend of mine who is
a vw mechanic. and forgot to add that
it has 10.5:1 comp.
a pic
Swap for a mild 1915?
What kind of power would this make? any idea
