Hi All,
I am not sure exactly what to call it, but I need the small spring from the base of a later Type 3 accelerator pedal. This is the spring that holds
the pedal upright and pushes it off the accelerator arm when you lift you foot off the pedal. Can anyone help?
Dean Robertson, Pm me or e-mail to condor-dino@netspace.net.au or phone 0400 908 346
Thank you, Dino.
tension spring or better; return spring
a good spring on the carbie end will help in the mean time
also first take the slack out of the cable
