hi there looking for rear drums for my 67 notch,but in porsche pattern, craig
gongetbuffed@optusnet.com.au
wyee nsw 2259
0405416405
i will be happy with just 4 stud type 3 drums so i can change the rear to suit the front 4 stud disc front,
Do you need just the drums or drums and hubs.
I should have both ,give me a call on 0243257911.
Peter
are you getting rid of some rear drums in wide 5?
would be interested if they are usable
chris
wrecker67... you need to be a bit more specific. are you after backing plates, or just drums?? call john sherman (@ volksconversions) if you just need
drums. should be able to get any pattern you want.
will need hubs as well,are the backing plates the same from the wide 5.
vwperformance is looking for me,
see how they go.
