I am after a plastic part that connects the heater tube of the body to the heater flexible hose that goes onto the heat exchanger.
Its a plastic piece that is rectantangle and has two bolts holding it to the body and then goes to a round hole that the flexible hose connects to.
Its the drivers side on a 1972 beetle.
Thanks Trevor
Where u at Trev ???
Wodonga
I havea look at Vintage for you today Its a brown plastic from memory ?? drivers side
Yep thats it
I should have some if Dave can't find and, but by memory you need the body off the pan to fit one without cutting it up first.![]()
oh no
That will screw me big time, is it just a few bolts that hold the body on, could I undo em and jack it up in that corner to get this part on or the
body has to come all the way off.
Yeah .... just a few.....32 or 36 ring a bell
